2006 V70 -- High Beam Detent on Directional Stalk Busted Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Can't get my high beams to stay on. "Flash" function works great, I just can't get the high beams to stay on. The high beam detent doesn't seem to grab.
Time for a junk yard directional stalk?
Anybody else experience this?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
There is no 'detent'. It's a momentary contact switch merely used to tell the CEM you've pulled on the stick:
If flash to pass is working the stick on the steering column is fine. Either the lights aren't turned on at the headlamp switch in which case you get flash to pass instead of high/low function. Or there's a problem with the headlamp switch: It's turned clockwise to the 3 o'clock position, but not telling the CEM that you've selected night driving/head light mode instead of daytime DRL+flash to pass behavior. The CEM controls the headlamps through relays. The headlamp switch is a data device and does not directly supply power to any of the actual lights. Nor does any of that 'working current' loop through the switch on the stalk.
I know this is a bit snarky: Have you recently let someone else drive the car?
Has thanked: 1502 times
Been thanked: 3817 times
Evan..are you sure the highs aren't working! I think the flash puts on both highs/lows so there are actually three modes of operation low, high, flash.
Blue indicator lighting up in dash? Is that bulb good?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Turn the light switch to position II.
In position I the stalk is flash to pass.
In position II the stalk is High/Low.
Position I is normal running.
Position II is high beam running.
E Showell
Post by E Showell »
Doh, says Homer Simpson, with accompanying forehead slap. Light switch was off. Thanks all.
'95 855 auto (sold)
Unlike P80s you can't switch DRL on/off with the screw in the headlight switch, it has to be done in VIDA
mrbrian200
E Showell wrote: 08 Jan 2018, 05:28 Doh, says Homer Simpson, with accompanying forehead slap. Light switch was off. Thanks all.
It's ok. When I first bought the car (S60), I would be embarrassed to admit how long it took me to figure out how to get the trunk open without using the FOB. It simply didn't occur to me it might be like a SUV with the release on the hatch/above the license plate. Then there was the time I inadvertently pressed the valet button and thought the trunk release was broken. Fortunately I noticed the DIM message about it before I started taking anything apart.
