1998 S70 front hood latch
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
A common problem I know but now I can't get the drivers side latch to disengage at all. I saw a video about taking off the side light and going through with a homemade tool -- not doing that in subzero temps. Can you maybe use some vice grips or something and pull the cable harder from inside the cabin? Or do something from under the car? --thanks
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I did from it below on my Volvo 740, also popped the headlight and went that way.mar601 wrote: 16 Jan 2018, 07:38 A common problem I know but now I can't get the drivers side latch to disengage at all. I saw a video about taking off the side light and going through with a homemade tool -- not doing that in subzero temps. Can you maybe use some vice grips or something and pull the cable harder from inside the cabin? Or do something from under the car? --thanks
It was easier, less intrusive, from below..
Bought a very long flat blade screwdriver and a penlight. Either way it's still cold and a pain no matter which direction.
Try vice grips on the cable first.
- RickHaleParker
- Been thanked: 978 times
Have somebody pull the cable as you push down on the hood, quick shove and let go. If it releases, the latch(s) are out of alignment. Slightly loosen the bolts to the latches, just enough the latches will move if pushed. Close hood and push down, this will realign the latches. Open hood, tighten bolts on latches to lock it in place. Test to make sure everything is working.
Active
Past
Past
- 12 Replies
- 790 Views
- 4356 Views
Last post by MrAl
- 45 Replies
- 8063 Views
Last post by MrAl
- 2689 Views
Last post by bmdubya1198
- 948 Views
Last post by voom8
