2006 V70 2.5T. 275K miles.
Has started misfiring, engine loses power, mileage is in the dumpster. Problem doesn't start until after engine has run for a while, and usually not unless I put it under a load like accelerating into traffic. If I turn the engine off and restart, problem goes away for a bit. Check engine light is on and Engine Service Required message displays.
Replaced the ECT sensor.
Codes indicate
P0300 - Random Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0101 - Mass or Volume Air Flow Circuit Range/Performance
P0170 - Fuel Trim Bank
I cleaned the MAF sensor when I replaced the ECT. I'm thinking the MAF is bad, but before I spend money on one and install it, I'm hoping for some more experienced opinions. I'd hate to spend 130 on a MAF when $30 of sparkplugs would have done the job.
Coils? Sparkplugs? The pipe leading from the PCV vent is cracked and leaks vapor when the engine is running...don't think that would cause a misfire though.
Misfires, low power 06 V70
- Been thanked: 4064 times
Definitely pull plugs and check, and move your number 1,2 coils to new cylinders to see if the codes move.
IF there are over 100k miles on the coils, get some new ones in. Check the date codes - I hope they arent 2006...
- RickHaleParker
- Been thanked: 977 times
Have you tried clearing the codes and see which ones come back?
P0101
Check for air leaks in the air intake system, any holes in the plumbing?
Check for restricted air flow, how dirty is the air filter?
Contacts to the MAF clean and in good shape?
Possible source
P0101
Possible source
- Contact resistance or oxidation in the mass air flow (MAF) connectors
Air leakage in the intake system
Blocked intake system
Damaged mass air flow (MAF) sensor.
Active
Past
Past
- 1023 Views
Last post by vtl
- 678 Views
Last post by cn90
- 3102 Views
- 739 Views
Last post by MoVolvos
- 1636 Views
Last post by mandalynn81
