Curtain airbag deployed
keithf
Year and Model: 1997 850 T5
Post by keithf »
Hi Friends - my son was in a fender bender with his 2007 S60 T5 and the driver-side curtain airbag deployed. The car is very fixable, but I'm concerned about successfully replacing the airbag. I can get a replacement airbag on eBay, though various forums seem to indicate that I need to also replace an SRS module and/or a software reset at the dealer.
Does anyone know the exact parts and process to replace the curtain airbag?
Thanks!
1997 850 T5
2007 S60 T5
2009 S60 2.5T
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
If the car will not start it is in crash mode. You will need Vida-DiCE to get it out of crash mode.
Active
Past
keithf
Post by keithf »
Ahh - I should have added that detail. The car starts and drives. The SRS Airbag warning is displaying in the instrument cluster.
1997 850 T5
2007 S60 T5
2009 S60 2.5T
RickHaleParker
Replace the air bag and reset the SRS warning. Vida-DiCE can reset the warning.
Active
Past
keithf
Post by keithf »
Sounds easy enough! Thanks for the quick replies!!
1997 850 T5
2007 S60 T5
2009 S60 2.5T
RickHaleParker
Just make sure you disconnect the battery before you do any work. You would not want the new air bag to deploy when your installing it.
Hope he knows better or comes back and reads this.
Active
Past
keithf
Post by keithf »
Yep! Thanks for the reminder on that!
1997 850 T5
2007 S60 T5
2009 S60 2.5T
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
When a side airbag deploys does it take out a trim strip? I'm thinking the trim won't stay because the gripping ridge has been broken off.
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Georgeandkira wrote: 09 Feb 2018, 05:29 When a side airbag deploys does it take out a trim strip? I'm thinking the trim won't stay because the gripping ridge has been broken off.
It should break at least partially.
The air bags shouldn't deploy for just a "fender bender" though. I'd never want to fix and drive a car that had the airbags deployed. But each to his own.
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Rattnalle wrote: 09 Feb 2018, 05:37
All the bags in my car blew, serious crash totalled it. I got it after a body guy fixed it.
Has a salvage title, don't bother me.
I've never sold a car in my life.
Run em til they expire.
