I know we have the ability to tell the display to allow for additional XX gallons or liters (multiple choices) in VIDA. Is there a way to REMOVE a said number of gallons? Currently it looks like it is set for +2 gallons. I see no way to zero it or remove amounts. I currently have burned through 14 gallons by the time I have 6 remaining on the fuel gauge. From my understanding my tank is ~16.x gallons.
Could this be a single sensor acting up? The reason I ask is I had a "Bank A" sensor error some time ago that was cured with a tank of Techron. Does the ECU calculate the error based upon delta between Bank A and Bank B sensors? Obviously they should be pretty close with exception of cornering...
Gas gauge settings - VIDA - 1999 V70 XC 2.4T AWD
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
2023 Lexus RZ450e -66k
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Your tank capacity is: 17.4 US gals. (66 liters) All Wheel Drive
As far as the sensors and VIDA, I'm not sure, sorry.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- wizechatmgr
I keep seeing everything from 17.9 to 19.3 gallons. I had thought it was lower due to the AWD so that 17.4 seems likely.
https://www.autoblog.com/buy/1999-Volvo ... gon/specs/
https://www.edmunds.com/volvo/v70/1999/ ... res-specs/
https://www.google.com/search?safe=acti ... 3&bih=1042
http://www.nadaguides.com/cars/1999/vol ... pecs/Print
I may just have to place the 5 gallon gas can in the trunk and find out just how far off (or accurate) that gauge is...
- Has thanked: 1613 times
- Been thanked: 4078 times
I think I would go to the online manual or stop my and read mine on the way home. It's open, don't wake me up.
- wizechatmgr
Maybe after I get a couple of hours sleep in. After my morning taxi-like services, I get to bed right around 10 AM.
I think I'll connect VIDA this morning and see if it has anything new to report.
Our rule in our house is
No less than 1/8 tank in summer
No less than 1/4 tank in winter
Exception on a long trip where of course, the strategy is can I make it to the next rest stop without running out, not wanting waste a tank of gas in case of a falling asteroid
- June
- Has thanked: 523 times
- Been thanked: 261 times
Abscate, isn't below a 1/4 tank bad for the fuel pump?abscate wrote: 13 Mar 2018, 09:04 Our rule in our house is
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
I don't know if anyone has determined when the fuel pump cooling starts to get marginalized. Volvo says fill when the gauge hits the red area or when the yellow "Dumt Manlijus" comes on...thats swedish for low fuel, I think.
2 gallons should keep the pump happy I think. My fuel pump in my 1999 is original
- wizechatmgr
So, back out to the car with VIDA once 3 months of updates apply successfully. Isn't much else I can do today =)
I think the real concerns with fuel pumps are once they suck air and have no cooling. Some in-tank pumps use the fuel for cooling.
I know when mine ended up sucking air on jack stands the fuse almost immediately blew.
- 1210 Views
Last post by xHeart
- 1600 Views
Last post by Ben850
- 2419 Views
Last post by MadeInJapan
- 2887 Views
Last post by 98v70dad
- 1988 Views
Last post by jimmy57
