No front brakes
rribbke
Year and Model: 2001 V70
No front brakes
Post by rribbke »
Gang
I have a 98 S70. Neither front caliper is actuating when you press the pedal. The rears are stopping the car. The master cylinder is full, and when i pop the bleeders on the front calipers and press the brake pedal i get no fluid. Thoughts?
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Are the bleeders pointing up? How long has the car been sitting?
85 GLH, 367 whp
00 Insight, 72 mpg
rribbke
Post by rribbke »
The car is a daily driver. The bleeders are pointing up. The brakes have gotten progressively harder over the last couple of months and are to the point that I finally pulled the wheels to look at the calipers and that’s when I noticed the issues i described.
tryingbe
Has thanked: 1 time
Post by tryingbe »
Steel lines might be clogged or the rubber hoses. I'd take the rubber hoses off first to see if you have fluid there.
85 GLH, 367 whp
00 Insight, 72 mpg
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Depress brake and check that both lines on master cylinder will squirt fluid is the lines are loosened 1/2 turn. That car still has the front/rear split so a bad master cylinder can affect only front or back. Not impossible but unlikely both hoses plus at one time. The ABS can kill and individual front circuit or both backs as that is a 3 circuit system with both back on one circuit. Since both fronts are not flowing that effectively rules out ABS pump module as it is unlikely but not impossible that both the valves in module would stick shut at one time.
Clemens
Has thanked: 474 times
Been thanked: 219 times
Post by Clemens »
Jimmy, are you sure the front and rear brakes are split f/f and r/r. At least on the european models they are split diagonally f/r and r/f
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
