Wondering if anyone else has installed the Volvo Factory add-on Bluetooth/handsfree module in their XC90 (I have a 2005 XC, the stereo option just below their top of the line offering... forget what they call it).
Specifically, wondering if this install requires a dealership reprogramming to get it to work. Or is that only required if you have the top of the line sound system which requires installation of the mute option wiring harness and kit?
I am planning on installing the BT add-on this Friday and would like to be adequately prepared. Thanks in advance.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
If you have a 2005, pretty sure you have an amp under the passenger so believe you'll need a mute relay and harness (PN 31210174 for standard, PN 30775498 for premium). Installed in my 2005 back in 2006 (standard), and did my 2008 (premium) in 2015. For that one I had to cobble a kit together. No programming whatsoever required, pretty much plug and play.
There's a guy on Swedespeed (khnitz) who still has some old parts around, he also sells on Bonanza (eBay competitor). It's where I got the relay/harness for the 2008 (rest was bought used on eBay). He may know where to find one if you're looking.
Can PM me if you want, I'm reasonably knowledgeable about the install and am happy to assist.
Good luck !
*edit- typo, add comment, different PN
Good luck !
soundquest
- Year and Model: v70 2005
Weird -- I wrote my reply the day you responded and it looks like it never posted.
Thank you very much for responding -- I truly appreciate it. This is just the information I was looking for -- extremely helpful. I will definitely PM you as I have a few more questions.
soundquest
I realize the wiring harness below is originally intended for a Parrot BT add-on, but would it work if paired with a VOLVO BT add-on?
https://www.ebay.com/itm/VOLVO-XC90-PAR ... pO&vxp=mtr
soundquest
Nevermind... I just answered my own question (NO is the answer). I did find the seller on Bonanza that you mentioned and found the wiring harness that I need here; but it would appear he is sold out on Bonanza. https://www.ebay.com/itm/VOLVO-XC90-PAR ... pO&vxp=mtr
soundquest
soundquest
Doh! I meant to post this one in that last post, not the ebay one : https://www.bonanza.com/listings/Volvo- ... /221650696
- 1721 Views
Last post by a3inverter
- 2630 Views
Last post by mrbrian200
- 533 Views
Last post by seggs
- 3135 Views
Last post by osi22
- 4373 Views
Last post by matthew1
