1996 850R Hitting boost cut at 7-10PSI
bwe95
Year and Model: 1996 850R
Post by bwe95 »
Been trying to figure this out for a while now, I have a modified 850R w/ 5 Speed manual. PO has put forged pistons in along with a "tuned" ECU which I have been lead to believe is just a basemap tune. CBV has been bypassed with an IPD plate.
At around 7-10 PSI the car bucks hard like its about to throw you into the dash. It's not a mild shudder, its sudden as if you turned the key off and back on.
AFR stays around 14.7 idle and WOT@7PSI is around 13.0-13.5.
I have replaced Spark plugs, TCV, Intercooler, Vacuum lines, all hard intake lines and couplers, and Fuel Pump.
Any advice on what to look into next would be much appreciated as I'm at a loss at this point.
Has thanked: 1610 times
Been thanked: 4068 times
How about the CBV,the diaphragm on the turbo that limits boost to stock?
bwe95
Post by bwe95 »
abscate wrote: 13 May 2018, 01:54 How about the CBV,the diaphragm on the turbo that limits boost to stock?
The CBV was bypassed with an IPD blockoff plate by PO
:oops: :oops: :oops: :oops:
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I'd toss the CBV back in. It is likely unhappy about an engine parameter and cutting fuel.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
What's the ECU exactly? Turbo 850 never came with manual transmission in the US.
Bypass CBV and using what to replace it? BOV?
85 GLH, 367 whp
00 Insight, 72 mpg
