Dielectric grease on ABS pins
woodycaldercloggs
Year and Model: v70 1998
Has thanked: 23 times
Post by woodycaldercloggs »
Does anyone know if putting Dielectric grease on the ABS module pins where the harness attaches to would cause any problems. :?:
I have a 1998 V70 and an intermittent problem where the ABS light comes on from time to time for no apparent reason. :?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It wouldn't hurt.
You have a failing abs module,dielectric grease won't solve a problem.
Contact matty moo about it or...if you know how to solder....re-solder abs module yourself.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2200 times
Been thanked: 1852 times
OP is based in France. There was a thread recently from an MVS member in France who had a company repair his ABS module for him in Europe and he was really happy with the result. Guys name is Manovlov in Grenoble.
viewtopic.php?f=1&t=84041&hilit=ABS+mod ... r&start=50
Check the last page, the company was called Recar.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
woodycaldercloggs wrote: 21 May 2018, 02:38 Does anyone know if putting Dielectric grease on the ABS module pins where the harness attaches to would cause any problems. :?:
Hello there,
Dielectric grease helps to prevent oxidation and provides some lubrication, that's about all it does. It does not improve conduction on contacts that are already oxidized. So if you are using this on electrical 'pins' then it might help keep conduction higher over time, but they must be clean to begin with.
You might also notice a difference by unplugging and plugging back in several times, as most connectors have a built in "wiping" action that cleans the contacts as they mate so that could help too, then apply the dielectric grease for long term oxidation prevention.
Note that the grease is non conductive so it never aides in conduction, it just helps prevent oxidation which hampers conduction so in the long term it helps when the contacts are already clean enough to make good contact.
In the above i am assuming that you are using this on electrical contacts of some type. For mechanical parts it would help to lubricate but then i would have to recommend using a lubricant that is specifically made for the actual application.
