Adding myself A/C anyone is good at this?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I got a can of 134a with a gauge and went to plug it to the low pressure port. With the engine and a/8c running, when the clutch is engaged I read 35psi, when the clutch is off I read 55psi. The air is cold but not chilling cold. Anyone knows what is the problem?
small prints: evaporator sensor is fine, the clutch is cycling fine, the gap is fine
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Is the radiator fan clicking on?
oragex
Post by oragex »
Yes, it was running high
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
If the system was empty it needs purging otherwise air left inside causes icing.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Idling pressures are not meaningful. use a stick between seat and pedal and get it over 1200 rpm. Set fan to speed 3 or the equivalent on range. Give ambient temp and low side pressures. Is the line between accumulator and compressor chilling to near freezing temp?
oragex
Post by oragex »
I didn't check the line, will check it next time.
The gauge was set for 25C, the ambient temperature.
Went yesterday to put the hose on the low pressure port, without the bottle. When I pressed the trigger I got a lot of air coming out for several minutes. Only after 2-3 minutes the refrigerant started to come out and the cabin got cooler. To my knowledge the system was never empty but I'm not the original owner. When I got the car, the lines were freezing up (bad evap sensor, I replaced it)
I wonder if the previous owner tried to refill with 12a or maybe even overfilled? I've seen another video on S60 and the gauge goes to 50psi when the clutch is engaged but falls down to 0 when the clutch is off. Plus, my clutch cycles every 10 seconds or so.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
How could you tell the difference between venting air vs venting refrigerant (when you put the hose on the LP port w/o the bottle)?
Has thanked: 1610 times
Been thanked: 4065 times
The best way to get the right charge is to vacuum it out, and add by weight per the sticker on the hood. 50 psi with clutch in sounds high, very high
oragex
Post by oragex »
The 55 psi is with the clutch off. Is it too high?
oragex wrote: 22 May 2018, 07:22 The 55 psi is with the clutch off. Is it too high?
No, with the clutch off that number doesn't really mean anything.
