Hello!
so, this all started when my speedometer quit working a while back. Found one on EBAY, replaced, speedometer working again. in the process of replacing the speedometer I reused my old odometer. Winter came and the project lagged. I need to work on the dash cover and things piled up, you know how it goes...
so I started driving it again recently and noticed that the odometer isn't working. Here are the details:
VDO Cluster
speedometer works
ABS light OK when starting car
ABS light not on
disassembled instrument cluster again: gears OK
checked ohms on the stepper motor connector: two readings of ~80 ohms, one reading of 160 ohms. one pin not connected, this appears to be what I should expect from a good motor.
I'm not sure where to go from here.
BR
Dwain
1995 850 - Odometer Not working
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The small white gear is ok?
Probably a bad wire in the harness at the top of the cluster. I had to repair 4 of mine.
- Year and Model: Many Volvos
- Been thanked: 76 times
There are two versions of the odometer and I'm not sure which version is used on a '95. On the early version the stepper motor for the odometer has a pigtail that plugs into a socket on the cluster main board. That version is fairly foolproof so long as the wires get plugged in. On the later version the stepper motor has a daughter board and there are pins that extend up from the cluster motherboard and plug into sockets that are integrated into the odometer daughter board.
I have had some trouble with the later type not working reliably unless you give the pins a spray with contact cleaner and "firmly" press the daughter board on when reassembling the cluster.
- rspi
Contact rspi..
The pre '96 cars use one and the post '96 cars use another.
I drove around for about 2 weeks with my dash pad off chasing my broken wires.
- 2007 Views
Last post by Ozark Lee
- 3187 Views
Last post by polskamafia mjl
- 1634 Views
Last post by precopster
- 744 Views
Last post by interace2
- 972 Views
Last post by ARMeyer27
