2001 volvo s80 check brake light
Yuri
Year and Model: 2001 s80
Post by Yuri »
2001 volvo s80 2,4
When I push to brake pedal i see writing: check brake light.
Sometimes to shine only the top stop-signal, sometimes all 3 lamps, any lamp sometimes doesn't shine. Always there is an inscription "check brake light". If posible problem in swich under brake pedal? I need brake light circuit ?
Yuri
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Just guessing, but I would expect the switch at the pedal to be working since it actually activates the message. Could it rather be an issue with the cables to the bulbs? Maybe also ask on the S60 forum, the S80 forum does have users but much less.
Here's a video if you want to inspect the brake pedal switch
Yuri
Post by Yuri »
the probema has begun when one brake bulb, then another has fused
Yuri
Post by Yuri »
There was everything simply - the relay doesn't work.
But it is strange that brake light works even at the removed socket from brake pedal switch now.??
The brake pedal switch 2001 volvo s-80 is under a cowl. And it have resistance in the pressed provision of a brake - 200 ohms, in not pressed - 1500 ohms.
