The silver one is a 2001 year with 200k+, the white is 2002 with 130k+. I'm driving the white one as best I can with the problems.
2001 model:
Blown head gasket - I let it overheat a few too many times from bad radiators and hoses...
2002 model:
Bad transmission - It shifts hard and slips just like all the known trans do when they fail. It actually has done it soo long that the CV joints are failing with the shimmy under acceleration problem people have reported when CV's fail
I'm kind of bummed because I knew the 2001 models had the bad solenoid problem so when I was shopping to get a new one, I went for 2002 year, but didn't realize that some of that year's models actually still had the 2001 model defective trans. Mine is one with the bad serial #
2002 trans
Now here's the rub: I drove the 2001 silver one for a few years just fine and never had any trans issues with it. I bought it used without any maint records, but I think it's trans has been replaced. The gasket underneath where the engine and trans meet does not seem factory; it kind of pokes out a bit and looks like that tan cardboard style gasket. And there is no serial number plate on the transmission. So I think it's not factory or the original and I could use it to replace the transmission in the white 2002 model
2001 trans
So here's the question:
1. Should I put the "good" transmission from the 2001 into the 2002? I'd have to do something about the broken CV's in the 2002 also.
2. Should I just fix the head gasket in the 2001 and keep the good trans in it?
3. Should I fix the broken trans in the 2002 and replace the trans solenoids and CV's?
I'm fine with leaving one of them as a parts car. The silver is kind of a parts car now, but the wife unit thinks it looks better than the white one so she wants to resurrect it...
2001 model:
2002 model:
