Hi all,
So after battling my car back from the grave (blown head gasket from broken water pump propeller) all I have left as a check engine code is for the throttle body position sensor
I already went to junkyard and switched out the throttle position sensor with another one. It could be possible I used a bad one again...
Other than it being the sensor itself, what other issues could be causing this code to fire?
It would be great to not have the check engine lights glow burning a hole in my brain.
Code P0120 - Throttle Position Sensor
- Has thanked: 311 times
- Been thanked: 817 times
How is the TPS connector on the wiring harness, and the little pigtail back to the main harness? Maybe a wire got pinched etc.
How about the fuel relay under the radiator cowl, is it connected well and its connector not falling apart? I have read of problems with this relay affecting the TPS, but I've never checked out the wiring diagram to try to understand why.
Dmck
- Year and Model: 1995 850
- Has thanked: 2 times
- Been thanked: 3 times
I'll look into it. I fooled around with the wire a tiny bit this morning and reseated it into the TPS
When I first start ignition the check engine light isn't on. It takes a second to click on.
If I start the engine and then rev it or take out of park, it turns on right at that moment of either of those actions.
If it were wiring I would think it would be an automatic check light and not delayed, but not sure.
I'm going to take off the intercooler tube tonight and fiddle
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No...the ecu will need to go through about 3 check cycles before it sets check engine light ON.Dmck wrote: 07 Aug 2018, 13:29 ...If it were wiring I would think it would be an automatic check light and not delayed, but not sure...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
marcello916
- Year and Model: 1996 850 turbo plat
did you ever figure out the issue? i have the same problem right now and the check engine lights is annoying meDmck wrote: 07 Aug 2018, 13:29 I'll look into it. I fooled around with the wire a tiny bit this morning and reseated it into the TPS
- 707 Views
Last post by 850brat
- 5139 Views
Last post by Raindog92
- 1542 Views
- 2215 Views
Last post by jking4020
- 13 Replies
- 7253 Views
Last post by markthomas1967
