Is this the best repair for the inevitable 850 horn failure?
http://www.odometergears.com/documentat ... lation.pdf
Volvo 850 horn contact set - question
- Year and Model: Many Volvos
- Been thanked: 76 times
I very rarely (as in never) use the horn so I have never experienced a failure. That said, I have been nothing but happy with the gears they provide and I'm sure the horn kit is of similar quality.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Odometer(s): That's the next fix. None of my 3 odo's are now working. FCP actually sells a kit containing both gears plus 4 lamps (for while we're in there) for $29.00. I think they're from the same vendor.
I seldom use the horn either. But just in case, on my 93 that had failed contacts I just installed a horn button on top of the steering post shroud just forward of the steering wheel. I had to use a relay, and it sticks a little during cold weather, so sound trails off for a second or two. A correct fix would be better.
I talked with an 855 owner yesterday whose horns were stuck blaring when the key was on. Searching the web I discovered that failure in the "on" position is not uncommon.
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
JimBee wrote: 08 Aug 2018, 21:53 Is this the best repair for the inevitable 850 horn failure?
200% yes!!! I have the kit myself. Crazy part, before I knew about it, posted here too.
My mechanic thought I was crazy because they could never ever get the horn to beep.
Then I hunted like a wolf, found those guys, called them up. It works never ever had a problem.
And my stupid mechanic said “hey you figured it out” as if he believed me all along.
Get it! These guys make great kits. Wish they made more!
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
viper69
No they don't. They should know, feel free to them! They were great to talk with. I'd buy anything they made for a Volvo. This kit was a lifesaver.JimBee wrote: 11 Aug 2018, 15:34 @viper69: that's some testimonial! Do the vendors know about this post? They should be paying you a commission. Looks like the one I'll be installing.
Volvo 850 GLT 1995
- 4085 Views
Last post by MazdaDude
- 1900 Views
Last post by subzerocarfanatic
- 838 Views
Last post by cn90
- 1345 Views
Last post by jimmy57
- 2371 Views
Last post by matthew1
