high beams short
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
virian11
Year and Model: 1988 740 volvo
high beams short
Post by virian11 »
Looking for solution to no head lites or high beams. when i switch to high beams number 2 fuse blows do any of you have a clue where to start??? thanks Virian11.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
You're going to be asked about the year and model. I see 1988 Volvo 740.
1988 Volvo 760 Turbo Wagon
virian11
Post by virian11 »
I own a 1988 740 Volvo sedan, this car historically was a Wyo-tech, student project car! i purchased to car, it has low miles on it, 165.000 miles, which is low for a 1988 Volvo, it appears who ever worked on this car was a complete "Empty-Head" like he as at a "Pic-n-pull! they literally took everything apart on the left side of this car, (not unbolt or unscrew) but just pull and "Rip" including headliner, and door panels. I was able to put everything back together until i ran into the head-lites and tail lites and high bean lites! When i turn on the high beams, the number 2 fuse blows, i haven't changed to switch yet because it appears there is i short between the switch and fire wall, i just need to look further but i did not want to dig through that jungle under the dash. when i went to all of the "So-Call-Volvo, guys and mechanics, the 1988 740 sires is out of their reach. so it looks like i am going to dig in!
lummert
Post by lummert »
Fuse #2 appears to be fed by the junction block (Red wire) then on other side of fuse goes to the combination switch (red wire) and the locking relay (red wire). Combination Switch being the turn signal/ high beam switch.
