I have a 2008 3.2 FWD XC90. I have recently replaced the coolant bypass hose (30713530) and the o ring (30670569).
It seems to hold for 40 or 50 miles, then start leaking again. I replaced the o ring again in case I had pinched it. The end of the fitting is popped off each time it leaks and I take it off and reinstall. It pressed back on, but I think it is coming loose while running and allowing the o ring to lose its seal.
Has anyone run into an issue like this, or have any tips to keep it from leaking the 4th time around? I am about to the point of using some high heat epoxy to secure the tip onto the fitting to see if that solves the issue.
Right now I'm stuck in a real seedy part of Fort Worth waiting on a tow truck...
Recurring Coolant Leak at Bypass Hose
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
What if the oil cooler is plugged and the pressure is high and blowing that out? The end of the fitting is a taper that pushes on the o ring. If the force there gets too high then it deflects at that "ear" and then the o ring moves. See if a garden hose can push water through the oil cooler.
Those style oil coolers are plugging up on many engines that use them. The small passages are ripe places for coolant to coagulate.
jimmy57
You could try cooling system flush. To test pull off the hose that's leaking and the one on bottom. You can first try flushing from top to bottom and then bottom to top.
jimmy57
Test coolant tank cap for pressure relief. It is a 21 psi release cap. Those fittings have not been leaking like yours. Some have cracked and are replaced and it's done.
