I pulled and exchanged the ETM on my 2000 V70. I removed turbo tubings and the cooling fan/shroud assembly, then removed the intake pipe from under the ETM, then dropped the ETM, and started replacing the parts in reverse order. I ended up with two small screws that I DO NOT KNOW WHERE THEY CAME FROM. Lame, I know. They are 8mm and about 3/4" long. Anyone? They obviously hold something small in place but I racked my brain and I cannot recall removing them or where they go. I attached a pic. Anyone have a clue?
Where do they go? *pocket part*
robbiewilso
- Year and Model: V70 2000 XC SE
- Has thanked: 2 times
- Has thanked: 1853 times
- Been thanked: 1714 times
Back of the radiator up near the top. One either side. They are kind of hidden maybe 4" from the top and screw into the front slam panel.
robbiewilso
*SLAPS FOREHEAD* Dang as soon as I read your reply I still could not picture it and then as soon as I raised the hood- BAM- there they were. THANK YOU THANK YOU THANK YOU.
Hey we have all had those moments (some of us more than others!). Glad to help.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
My policy after removing something is I thread the bolts back into the holes where they came from a few turns. Hence you can't fit whatever it is back on without removing the bolt or screw that belongs with it. Life is much easier since I started doing that.
robbiewilso
I def have used that technique but i had to yank the rad fan out so didnt want anything to get in the way
- Has thanked: 1506 times
- Been thanked: 3822 times
On a big job, baggies, business card notes in bag, reference number on bag, and put number on printed out workflow,
I consistently beat book because I don’t get lost wondering what
If you mark the bag with M8 10 mm you also know what tools to use and what to,replace bad hardware with, too.
- 216 Views
Last post by kranz
- 1606 Views
Last post by liquidBlack
