I found out my upper torque mount is failing.
I plan on replacing that. It seems that for this style mount I just buy the whole mount and not just the bushing. Correct?
It seems that on 98 s70 and 850s they used a different style upper torque mount when compared to my 99.
I'm curious. What symptoms would I expect if that were to fail completely?
Thanks... -A
What happens when upper torque mount fails
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Expect extreme vibrations, hard shifts, and undue strain on the transmission, exhaust, and axles.
Knows enough to be dangerous
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Vibrations are not extreme...it's noticeable a bit more than normal at idle,shifting have nothing to do with it or the rest of the car.
The symptoms you're discribed would be present if complete assembly would have been removed from the car.
Extreme vibrations are present when lower right engine mount is broken(under the crank pulley) or lower left.
'99 have different style mount...but bushing is available as separate part...no need for complete assembly.
Meyle HD(not regular Meyle) have that bushing and it will last more than OE.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4064 times
I bet there is a Scot in Calgary who will say thats less than half used up...
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
Ha. I know. Right now it is just 1/2 torn. But I'm changing my oil this weekend and I figure I'll just replace that mount along with it.
I had a parts car in my driveway a while back where that mount was completely destroyed and probably had been for years.
- Has thanked: 2197 times
- Been thanked: 1851 times
Well got to look at the positives! Issue is when it fails it puts more stress on the lower torque mount (available for FWD but not for AWD) and the mount under the crankshaft pulley. The biggest issue is that the upper radiator pipe has little flex. Failing top mounts allow the engine to twist further backward and can eventually cause the upper outlet on the radiator to crack and break and flex the RH end of the radiator causing it to split. So don't delay!!
Other than removing the spark plug cover, it is held on by 4 bolts and the bolt through the torque mount. 30 minute job, 1 hour if you have any of the spark cover bolts that are stubborn. Check the location of the 4 mounting bolts for the mount as they are different lengths.
- 1715 Views
Last post by kosh_al
- 1767 Views
Last post by landl4u2
- 537 Views
Last post by xHeart
- 1926 Views
Last post by rspi
- 19 Replies
- 3514 Views
Last post by theWIFES_S70
