Misfire code on all five cylinders?
Hi guys, just picked up a super nice one owner 97 NA 5 speed. Had the timing belt and all components changed and then got a 6 misfire codes, a general misfire and then one for each cylinder. It seems to run fine although it feels a tad sluggish. I know they’re not necessarily quick cars. It’s guzzling gas too, but it runs super smoothly. Any thoughts? I’m going to start with a tune up kit and clean the MAF this weekend but what else should I look at? Thanks!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If misfire codes showed up AFTER timing belt replacement i would re-check timing...could be that it's 1 or 2 teeth off...3 is a game over.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
SteveV70
- Year and Model: 2007 V70
- Been thanked: 3 times
Five speed,…nice.
I also have the same configuration in my 07 V70.
When I got it,…it had the misfire on all cylinders, random random.
After replacing all the coil packs,…still issues.
Replaced the MAF and it cleared everything up to perfect.
It’s pretty zippy once you get it sorted out, and you should get around 30 mpg on the highway.
Keep us posted when you get it worked out. I like to see the results of when people finally find the problem.
Too many just disappear and we never know what fixed it.
bskeels
- Year and Model: 1997 Volvo 960
I would check the vacuum connector at the end of the manifold, I had a issue with individual and multiple on my 98 shortly after purchasing it, changed the plugs, cap, rotor and wires, still had the same issues, check the forum and then the elbow at the manifold. It was cracked, once replaced it cleared up my misfire.
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
- Has thanked: 311 times
- Been thanked: 817 times
The suggestions are still good to know of course but ... Old thread alert, this is from 2019.
- 19 Replies
- 10197 Views
Last post by Barledge
- 938 Views
Last post by stephansvolvo
- 1742 Views
Last post by freebirdchampion
- 14 Replies
- 2733 Views
Last post by ToriWhite
- 16 Replies
- 1484 Views
