Bevel gear rebuilder?
- SuperHerman
- Been thanked: 207 times
I would recommend you search the XC70 world for answers. On my XC70, when my bevel gear melted, I ended up sourcing a used unit and resealing it before I installed it. During the process I found a number of people that replaced actual hard parts, bearings, to achieve their repairs.
The bearings are pretty common and the numbers will be stamped on the outside. Reality is that only bearings can be found, at least when I looked. The actual gears were not available.
Volvo has a technical bulletin on resealing the bevel gear (for XC70) - read through it - it will give you some idea of what is going on. Here: http://www.volvoxc.com/0/resources/how- ... eakage.pdf
After this point, it is just pulling out the offending bearing, replacing it, setting up the torque and resealing.
A used unit may be your best option unless you can be without the vehicle for at least a week. If after you have read up on the process, and feel you can handle the matter, buying the bearing before hand would speed things up. Other option is to call a transmission repair shop and ask them to do the rebuild, but a used part may be cheaper. If you go with a used unit, change out the oil and seals while it is out.
Were it me, I have a spare vehicle for this exact purpose, I would read up and make sure I don't have to do any "preload" type of work on the bevel gear which I cannot perform or find specs for. If the pinion bearing is just a swap I would tackle the job. I would start by comparing the XC70 unit to the XC90 unit, looking for bearing interchange, and any other relevant spec I can find. Then order the part and in the interim, prep the unit for install. Next I would pull the unit out, open it up, and see if it can be rebuilt.
Here is a start: https://forums.swedespeed.com/showthrea ... or-failure
- 2921 Views
Last post by MoneyPitC70
- 1049 Views
Last post by JDS60R
- 2557 Views
Last post by cn90
- 3595 Views
Last post by mrscullini
- 1034 Views
Last post by dkarpe8
