Overdrive not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
87240DLWagon
Post by 87240DLWagon »
It is not the button, the over drive off light stays on and it never engages. Is there a simpel thing i could do like cross 2 wires and just have over drive on permenately? What is useully the problem when overdrive will not engage.
Thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You haven't said whether this is manual or automatic but both types of overdrive are operated by a solenoid which is mounted on the gearbox casing.
Fuse #11 on the 87 240 is for the 4th gear on auto boxes and here is a relay for the auto transmission overdrive behind the dash to the left of the glove box.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
87240DLWagon
Sorry its an auto. Is there a way to test the relay?
billofdurham
The only way is to replace it with a known good one - Catch 22 situation unfortunately.
Sometimes giving a dodgy relay a hard flick with your finger can kick start it, but no guarantee.
Bill.
Previously:
87240DLWagon
Could i simply get rid of the relay and make overdrive permently on? By hooking the 2 wires together
billofdurham
This could be dangerous. You would need to know that the overdrive was engaged before joining the wires, because to engage it after joining them would be done without the relay in the circuit causing a heavy current on parts not designed to take it.
In any case it may not be the relay that is at fault, it may be the solenoid itself.
Bill.
Previously:
87240DLWagon
I just found this
http://www.ipdusa.com/ProductsCat.aspx? ... RootID=629
Will this kit cause problems? Recomend?
LaRy
Post by LaRy »
If you have some skill in soldering you can open the OD relay and make it work again. The most common problem with this relay is that the soldering joints gets cracked after 20 years. Open the relay carefully, no problem to do that. Resolder all joints at the pc-board that looks bad, like frosted or cracked. After this, the relay will work for 20 more years.
jr86565
Post by jr86565 »
If it is a stick I found the wires for the button on mine had broken where they came out the bottom of the hollow shifter extension after pulling up the carpet and my break could be found by chasing the wires from the relay. Mine is a 84 245.
