Pulled the cylinder head B5254T
- Year and Model: Many Volvos
- Been thanked: 76 times
It isn't corrosion, it is carbon deposits and it is pretty normal. A Seafoam treatment every year or two helps burn the stuff off.
V70xc1999
- Year and Model: 1999 v70 c.f. 2.4 Tu
Thanks. Another quick question.....i gor some valve stem seals in the kit.....Victor rainze.....are they a reliable brand? Is is better to just put them in for now instaed of leaving the old OE ones? Thanks
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
why did you pull it? interesting 1 or 5 (cant tell which) has different burn pattern. wire brush the deposits off as they cause predestination. ( hate the spell check, not sure if its my computer or this site?)
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Always replace a head gasket - they are typically a single use item.V70xc1999 wrote: 27 Apr 2019, 19:34 Head Gasket.......should I install them....if it a good idea to do so....I am planning on using the valve grinding compound to clean vavles and vavle chamber's
Wouldn't necessarily use valve grinding compound on all that, it isn't really needed. A brass brush will do wonders.
V70xc1999
Ok I am asking are the Victor Rainze valve stem seals reputable...are they good to install and wont have to be back in the engine...i know some gaskets and seals ...( I am replacing head gasket its blown..... Thats the whole reason I'm doing this....) Are the victor rainze valve stem seals good?
tardcart
we dont know if the seals are good, people are afraid to try them. Probably they would be be better than 20 year old Volvo ones.
rubber parts in a hot oil bath really have to be right. Dont use any valve compound. lapping the valves ruins the undercut on the seats. take each valve out and wire brush it (on a motor) and put it back in the same hole it came out of. particularly clean the stems of build up. If any of the valves wiggle in the guide or you see any burning on the seat or if any valve wiggles when spun in a drill then you need to take it and have a valve job. most would take a light surface cut on the head but you can check with a straight edge for warp. If the leak caused metal loss then you need to surface the head. People have said the victor head gaskets work.
which cylinder(s) had low compression, could you see it on the head gasket? what were the symptoms?
- DeadEric
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
- Been thanked: 12 times
I've always taken heads to a machine shop (call around for one familiar with Volvo.) If I know I don't know, it's better to pay someone to do it right.
The fee should include cleaning, plaining, valve checking, leak testing and lubricating.
A good shop will also stand behind their work and use quality parts if replacing is necessary.
- 5767 Views
Last post by SvenGWK
- 775 Views
Last post by wanderdüne
- 622 Views
Last post by Gtin
- 2145 Views
Last post by precopster
- 13 Replies
- 8389 Views
Last post by lifeofgold
