Oil leak after routin oil change
Mattvh
- Year and Model: 2001 s 80
- Has thanked: 1 time
Hi I have a 2001 s 80 non turbo. After I changed oil, it has been leaking from the passenger side. I can not locate the leak. The only variable I can think of [first time working on Volvo] is that I did add oil to the oil filter about half way. Anyway, it did not leak oil before the oil change, but not is it leaking oil. Any help would be great thank you.
Mattvh
Update on oil leak. Saturday I investigated the oil leak. On the engine block, above the drive axle mounting location on the passenger side, is a “hex” style bolt. The oil as best I can tell was dripping oil from there. The thing is, when I went to tighten it, i don’t believe I moved the bolt, not even a millimeter! But I must have just the littlest bit, because that did stop the leak. Thanks for all the help
- 11 Replies
- 15908 Views
Last post by RossJonnes
- 19 Replies
- 5111 Views
Last post by erikv11
- 1503 Views
Last post by mortaay8444
- 64 Replies
- 10667 Views
Last post by plumsmooth
- 1665 Views
Last post by polskamafia mjl
