ECM-5000 Topic is solved
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
Our 2006 XC70 185kmiles, start sometimes harder. The throttle body has been cleaned.
Scanned for codes and got among other things ECM-5000( first time)
I have cleaned the Electrical connector from the crankshaft position sensor, but no improvement.
Directly after cleaning it was starting difficult and saw the rpm gauge spiking
I have checked Vida for the location of the rpm sensor but not very helpful. Is there a better picture available?
According to Vida also:
Signal Interference (from power cable to starter?)
Damaged fly wheel; how to check this?
Help would be appreciated
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Rvolvos wrote: 18 May 2019, 10:35 Scanned for codes and got among other things ECM-5000( first time)
Clear the codes, drive the car, scan for codes, come back and list all the codes from the second scan.
Active
Past
Rvolvos
Post by Rvolvos »
Okay thanks I will.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
There are 2 cam RPM sensors on a 2006 XC70. They are housed in round black plastic housings made by Denso. The intake one is clearly visible. Each has a connector. The rear one on the exhaust cam isn't visible until the top mount is removed.
Flyingfish
Year and Model: 1990 240DL Wagon
Has thanked: 3 times
Post by Flyingfish »
Rvolvos,
Did you ever resolve this issue?
I'm having much the same problem and would love to hear what you did to solve it.
Rvolvos
Post by Rvolvos »
Runs and starts much better now, I found out that he insulation from ignition coil wires where damaged / cracked. It was a miracle that the car was even running and or starting.
It only takes a bit longer to start when the engine is hot. But I am waiting on codes to come up before replacing cam or crankshaft sensors.
My advice to you is check the wiring on top of the block and on the side of the engine if you have a high mileage car.
Good luck.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
