98 v70 t5 320,000 never had pcv/ptc maintenance
Mark1967
Year and Model: 98 V70 T5
Post by Mark1967 »
Car was given to me 10 years ago. Runs excellent. Am looking to do pcv/ptc replacement and noticed all original hoses, clamps, etc. Is this possible with 320,000?
Has thanked: 1609 times
Been thanked: 4064 times
It is if the oil changes were religiously done every 5000 miles. I had mine at 160k and it was less than 10% blocked.
Mark1967
Post by Mark1967 »
Ok. I was just surprised that everthing is original. Never pulled codes and engine light has been on for years. Never needs oil. Drives amazing. Engine has oil on it from oil fill cap which led me to pcv system
Do the “glove test” and if you don’t have crank pressure it’s not needed.
The engine oil on top will come from your bad oil cap gasket. Cheap fix, but go OEM
https://www.fcpeuro.com/products/volvo- ... gLQe_D_BwE
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
abscate wrote: 04 Jun 2019, 01:07 Do the “glove test” and if you don’t have crank pressure it’s not needed.
FCP must have a stock of them because Volvo in Sweden doesn't sell the gasket anymore. You have to buy the entire cap. Or buy the gasket elsewhere..
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Rattnalle wrote: 04 Jun 2019, 04:24
FCP stock is quickly depleting, I just bought 10 of them the other day :D
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Rattnalle
Post by Rattnalle »
850 LPT wrote: 04 Jun 2019, 05:48
I'm pretty sure they'll find a new source for something as generic as a flat rubber gasket if needed :-)
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
Blech,...
Go check your turbo oil return line gasket....
Mark1967
Post by Mark1967 »
Where exactly is the turbo oil return line gasket located? Thanks
