S60 upgrade
S60 upgrade
Hello, I'm looking to upgrade my '98 S-70 to a '08 S60. Milage 88K. Any particular issues or trouble areas I should take a closer look at or be aware of with this model year? What types of problems occur? Thanks in advance for feedback.
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Be wary of everything rubber in that car; also, I would start changing oil every 3 - 5k in order to avoid the dreaded PCV issue. See if you can get one with the timing belt changed, and clean the throttle body in order to avoid MAF check engine light.
IPD gives a great summary of common problems with the car.
- 2654 Views
Last post by seanfish22
- 483 Views
Last post by matthew1
