04 V70 2.5T fuel pump issues
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Rgreiner
Year and Model: 2004
Has thanked: 2 times
Post by Rgreiner »
I have an 04 V70. It has a steel fuel tank so obviously it's an odd ball. I was in the drive thru at the Chic Fila and it just quit. Relay was clicking but no pump. I tried swapping relays that did nothing, then I replaced the fuel pump. Which took me a couple orders because of the steel tank thing. But it is a factory replacement pump from Volvo. Not a cheap piece!
Well it still doesn't work? Is there any other components between relay CMI12 under dash and the pump? I haven't found a proper diagram yet.. it doesn't help its 100deg outside working on it either. Any help would be much appreciated. Thanks
Has thanked: 1505 times
Been thanked: 3818 times
The P2 fuel delivery uses the central electronic modul (CEM) a pump electronic module. The Pump module Is the most likely failure,
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, look for the PEM (google) $50 used off Ebay. No need to put back the small locking tab and screw
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
I concur... PUMP ELECTRONIC MODULE.(I hate acronyms) btw. It good to have moderators like abscate, Oragex, Jimmy 57 and a handful of other people around... really know their stuff when it comes to the diagnostic side. MDK
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
You can find a used PEM at local junk yard for $15-$20.
Give it a try.
If not, then try ebay, about $45 for a used PEM.
Rgreiner
Post by Rgreiner »
Thanks for all your help. I pulled the module out today. It's pretty corroded. I'm gonna order another.
MDK wrote: 19 Jul 2019, 15:08 I concur... PUMP ELECTRONIC MODULE.(I hate acronyms) btw. It good to have moderators like abscate, Oragex, Jimmy 57 and a handful of other people around... really know their stuff when it comes to the diagnostic side. MDK
It’s an MVSBP* to not use AWOD**
*Matthews volvo site best practice
**acronyms without definition
WE can do a better job here of stopping this bad habit, which is tough on newer folks. I caught myself with one above but not the first one :cry:
