Can anyone help me, please? I have a 2004 S80, Non-Turbo model that is not running well at all. When it starts it is either rough to start or when it starts is has a rough idle. When you step on the accelerator the RPM's will not go over 2000. I ran a code reader and I get a P0105 code that says it is a Manifold Absolute Pressure/Barometric Pressure Circuit issue.
My problem is that I CAN NOT find the "Bleeping" MAP Sensor anywhere. Can someone please tell me where it is located and possibly post a picture or accurate diagram? Thank You
David
2004 S80 MAP Sensor Location
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Might help if you would state which engine is in your S80. Also I would advice to do a readout with DICE, might show some more info
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I think you are going to have to get a read with manufacturer specific codes. Some scanners will read the code in some coars and the conversion list to P type codes from manufacturer specific codes is wrong. There is no MAP sensor on a 2.9 non turbo as it has Bosch Motronic 7.01 and that system does not use one. I wanted to look up the code as sometimes the ambient temp sensor that is part of the MAF on that car will display a wrong code on a generic scan tool but that is not the code that sets.
jimmy57
It might but that is not a plug n play ECM change. The dealer can't install a used one and Xemodex charges $300 plus to clone your info from old one to a used one you supply. I do not trust the code you have to be accurate for the problem.
- 2434 Views
Last post by Ville1121
- 5985 Views
Last post by HMP12
- 19 Replies
- 5588 Views
Last post by MALL240
- 686 Views
Last post by PaulMartin
- 5036 Views
Last post by tflesui
