G'day,
My 2002 V70 NA threw the P0171 code the other day.
As part of the trouble shooting I am looking at the numbers for the various sensors on my OBD reader. It tells the RPM which is an obvious one and temp too but the others don't mean a lot to me but I suspect that they will help me diagnose the problem.
Can anyone point me in the right direction with a list of numbers or ranges of numbers that will let me know if things are within a correct range or really skew wiff.
The numbers relate to O2 sensors, short term fuel and long term fuel etc. I am just not sure what to search for on the site.
Any help gratefully received.
Cheers
DTC - Engine values
- Been thanked: 4071 times
That code is usually caused by a vacuum leak, which is caused by a crumbling hose somewhere.
Find the sticker under the bonnet which shows the vacuum routings and start pulling each one off, inspecting, and replacing . After 18 years, they are well past end of designed end-of-life
- 7559 Views
Last post by RdRVolvo
- 689 Views
Last post by Salomons Driveway
- 627 Views
Last post by benpineapple
- 1194 Views
Last post by stufftoknow
- 2206 Views
Last post by Steve H
