Volvo 850 turbo no crank
Turbobrick69
Year and Model: 1996 volvo 850 turbo
Has thanked: 1 time
Post by Turbobrick69 »
Hey y'all,
My volvo 850 turbo had a crank but no start issue, pretty sure it wasn't getting spark, i replaced the cam sensor, it was cranking and it took a lil bit for it to turn over then it it started, i let it run for a few minutes then turned it off to see if i could start her up again, now she wont even crank, could it be the starter?
Please help what do?
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There are several possibilities for the no-crank. At least on my car, the causes of a no crank have been:
The battery has been discharged too low to crank, or the battery has an internal fault (may read 12.6V at rest but the voltage sags below 11V during starting)
The positive cable between the battery and the starter is not making a good low resistance connection
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
...or P'n'P switch if it's automatic.
To rule out p'n'p switch,try to start it in 'N' position.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
