I'm in need of a full engine replacement for my -04 R. My R is Geartronic model and so far I have only found replacement engines that are from manual cars. Is there some crucial difference ie. engine mounting points? As far as I know, the flywheel from "manual" engine needs to be replaced with flexplate from current "automatic" engine. Should the flywheel/flexplate operation be simple or is there differences in the crank for example?
Thanks in advance!
Replacement B5254T4
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Someone has to look up the crankshafts of both engines and see if the part numbers differ.
I have VIDA so I checked them and they are same. The replacement engine is from S60R, but if I interpreted VIDA correctly, the engine mounting is all the same. Sorry that checking with VIDA did not come to my mind earlier.
- 4102 Views
Last post by rockster
- 5101 Views
Last post by jimmy57
- 3867 Views
Last post by remermn
- 39 Replies
- 8065 Views
Last post by northrancher
- 771 Views
Last post by cn90
