Crankshaft interchange
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Weitz1033
Year and Model: 2008 Volvo s40 2.4i
Post by Weitz1033 »
Thanks in advance for any help here. I have a 2008 s40 2.4i with "39" vin and trying to figure out what all models would have the same crank and rods to pull from a yard.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Crank and rods? ... Would you not be better off getting a short block that would work?
Code 39 is a B5244S7
SULEV+ engine variant with PremAir for California.
Applications: S40 II.
B5244S4 (code 38) Applications:
2004–2010 Volvo S40 II badged as S40 2.4i
2004–2010 Volvo V50 badged as V50 2.4i
2007–2010 Volvo C30 badged as C30 2.4i
2006–2010 Volvo C70 II badged as C70 2.4i
B5244S5 (Code 66) Applications:
2006–2010 Volvo C70 II badged as C70 2.4.
B5244S6 is a older version of the B5244S7, SULEV+ engine variant of B5244S0 for California.
The crankshaft and rods where used in a lot of different Volvo engines.
Crankshaft Volvo part number 9465780.
Volvo C30 2.4l 5 cylinder 2007, 2008, 2009, 2010, 2011
Volvo C30 2.5l 5 cylinder Turbo 2007, 2008, 2009, 2010, 2011, 2012, 2013
Volvo C70 2.4l 5 cylinder 2006, 2007
Volvo C70 2.5l 5 cylinder Turbo 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Volvo S40 2.4l 5 cylinder 2004, 2005, 2006, 2007, 2008, 2009, 2010
Volvo S40 2.5l 5 cylinder Turbo 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
Volvo S60 2.5l 5 cylinder Turbo 2011, 2012, 2013, 2014, 2015, 2016
Volvo S60 Cross Country 2.5l 5 cylinder Turbo 2016
Volvo S60L 2.5l 5 cylinder Turbo 2016
Volvo V50 2.4l 5 cylinder 2005, 2006, 2007, 2008, 2009, 2010
Volvo V50 2.5l 5 cylinder Turbo 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
Volvo V60 2.5l 5 cylinder Turbo 2014, 2015, 2016
Volvo V60 Cross Country 2.5l 5 cylinder Turbo 2015, 2016
Volvo XC60 2.5l 5 cylinder Turbo 2015, 2016
Volvo XC70 2.5l 5 cylinder Turbo 2016
Connecting rod Volvo part number 31251468.
Volvo C70 2.3l 5 cylinder Turbo Convertible 1999, 2000, 2001, 2002, 2003, 2004
Volvo C70 2.3l 5 cylinder Turbo Coupe 1999, 2000, 2001, 2002
Volvo C70 2.4l 5 cylinder Convertible 2000
Volvo C70 2.4l 5 cylinder Turbo Convertible 2000, 2001, 2002, 2003, 2004
Volvo C70 2.4l 5 cylinder Turbo Coupe 2000, 2001
Volvo C70 2.5l 5 cylinder Turbo Convertible 1999
Volvo C70 2.5l 5 cylinder Turbo Coupe 1999
Volvo S40 2.0l 4 cylinder Turbo 2000, 2001, 2002, 2003, 2004
Volvo S60 2.0l 5 cylinder Turbo 2004, 2005, 2006, 2007
Volvo S60 2.3l 5 cylinder Turbo 2001, 2002, 2003, 2004
Volvo S60 2.4l 5 cylinder 2001, 2002, 2003, 2004, 2005, 2006
Volvo S60 2.4l 5 cylinder Turbo 2001, 2002, 2003, 2005, 2006, 2007, 2008, 2009
Volvo S60 2.5l 5 cylinder Turbo 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2011, 2012, 2013, 2014, 2015, 2016
Volvo S70 2.3l 5 cylinder Turbo 1999, 2000
Volvo S70 2.4l 5 cylinder 2000
Volvo S70 2.4l 5 cylinder Turbo 2000
Volvo S70 2.5l 5 cylinder 1999
Volvo S70 2.5l 5 cylinder Turbo 1999
Volvo S80 2.5l 5 cylinder Turbo 2003, 2004, 2005, 2006
Volvo S80 2.8l 6 cylinder Turbo 1999, 2000, 2001
Volvo S80 2.9l 6 cylinder 2000, 2001, 2002, 2003, 2004, 2005, 2006
Volvo S80 2.9l 6 cylinder Turbo 2002, 2003, 2004, 2005, 2006
Volvo S80 3.0l 6 cylinder 1999
Volvo V40 2.0l 4 cylinder Turbo 2000, 2001, 2002, 2003, 2004
Volvo V70 2.3l 5 cylinder Turbo 1999, 2000, 2001, 2002, 2003, 2004
Volvo V70 2.4l 5 cylinder 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007
Volvo V70 2.4l 5 cylinder Turbo 2000, 2001, 2002, 2003, 2005, 2006, 2007
Volvo V70 2.5l 5 cylinder 1999
Volvo V70 2.5l 5 cylinder Turbo 1999, 2003, 2004, 2005, 2006, 2007
Volvo V70 XC 2.4l 5 cylinder Turbo 2000, 2001, 2002
Volvo V70 XC 2.5l 5 cylinder Turbo 1999, 2003, 2004, 2005, 2006, 2007
Volvo XC90 2.9l 6 cylinder Turbo 2003, 2004, 2005, 2006
Weitz1033
Post by Weitz1033 »
Thank you so much for the great info. My apologies for my ignorance, but I'm not familiar with forums at all. Of all the items listed it's only the ones that are highlighted that will work, right?
Also I think you may have a point about the short block. If it's not too much trouble can you let me know what all models I can pull a short and long block out of.
RickHaleParker
The Crank and rods from anything listed above will work. I highlighted the 2.4L.
For a long or short block, you cannot go wrong by sticking with the B5244S4, B5244S5 or B5244S7 listed above.
