2003 V70 non turbo
Mohjoh71
- Year and Model: 2003 V70 2002 S60
This a new issue. When I start it, the engine revs all the way up to red line. I shut it off quickly and waited a minute and then it started normally. It's done this 3-4 times recently. Any ideas?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Of course, first I would look at the floor carpet, in case the pedal gets stuck somehow.
How many miles on it ? If it's an early 2003, do you have the Marelli ETM ? Looks like this https://www.google.com/url?sa=i&rct=j&q ... 9873313935
Maybe an engine management problem ? Normally the engine will rev around 1500 rpm to heat up the cat and build some vacuum, maybe a sensor is fouling the ECU ?
Less probable, but maybe also an issue with a leaking injector ? I'm thinking, injectors leaking overnight some gas inside the cylinders.. just a theory..
- RickHaleParker
- Been thanked: 979 times
Add large vacuum leak to what is listed above.
Active
Past
Past
- 833 Views
Last post by oragex
- 11 Replies
- 3440 Views
Last post by draser
- 15 Replies
- 5386 Views
Last post by enriquepr21
- 575 Views
Last post by br0dy519
- 535 Views
