Car Will Only Run with MAF Unplugged
ChipmunkPizza
Year and Model: 2001 S80
Has thanked: 3 times
Post by ChipmunkPizza »
I posted previously on here about a crank/no-start issue that was remedied by unplugging the MAF. This led me to believe that the MAF was at fault, so I purchased and installed a new Bosch MAF from ipd. Unfortunately, this did not fix my issue and the car still won’t start with the MAF plugged in. With the MAF unplugged, the car will start and run, but very poorly. It’s smoking excessively, despite a compression test indicating properly functioning rings (150 psi per cylinder). If I plug the MAF in while the car is running, it will eventually die and not start up again. Any help is appreciated, thank you.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
ChimpmunkPizza - sounds like you have a wiring short somewhere. If you have a VOM you can do some testing starting with the harness and going back to the fuse box. Also check your O2 sensors for short to ground.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Any update, any fault codes?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
