Hello all.
I came across a set of matching headlight assemblies from an '04 V70 and was wondering if the would fit in an '05 without a lot of modification? I really like the glass v. plastic lens. I compared pics online, and I am thinking it is not possible, but I thought I'd float this out there to see if anyone else had tried.
Using a headlight assembly from a '04 V70 on an '05
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Might get more responses if title matched subject matter -- headlining v. headlight.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
tony2phones
- Year and Model: 2006 V70
Long time gone but I've done it. best way is to either get the loom with the lights and splice in to the existing plug or cut off the round plug and splice on a 4 pin older plug. You NEED the 4 pin connection with a bit of wire to attach to rather than messing with pins and clips.
The units are a straight swap with a bit of fiddling on the alignment its the pigtail that's different and needs rewiring.
- 686 Views
Last post by vtl
- 376 Views
Last post by VolvoNinja
