Front end shakes after warm up
Mthafukngreen
Year and Model: 01 s80
Post by Mthafukngreen »
First off, my control arms are bad and I'm sure that's playing a big factor. Secondly, my brakes are kinda sticky, that may be another factor.
Anyone got any ideas as to why the shaking only happens after the car reaches operating temperature?
It starts out subtle but the longer I drive after it's warmed up the shaking gets worse and worse. If I park for a 10 minutes or so, I can drive shake-free for about 5 minutes. If I let the car cool down completely, I'm back at square one.
Help lol
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Mthafukngreen wrote: 20 Feb 2020, 03:05 Secondly, my brakes are kinda sticky, that may be another factor.
Heat
Brakes are energy converters, they convert Kinetic energy into Thermal energy then dump the Thermal energy into their environment. Brake shoes expand when they heat up and would stick even more.
Active
Past
Mthafukngreen
Ok thank you. You confirmed my suspicions.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
your brake hoses could be swelled up from the inside due to age (and perhaps bad or old fluid, I am not sure about that one). As you drive and use the brakes, the pads get applied to the discs ok, but because the hoses are constricted, aren't able to retract. If this is your problem, you would have extremely hot brake discs and noticeable drag when up to temperature.
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Post by ndphotonl »
Be very cautious with dragging brakes, the rotor will become very hot
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
lasseamager
Year and Model: volvo 2002 s80 t6
Post by lasseamager »
front disc are ....not straight but. yeah you know, and if the brake caliper is bad , it gets MUCH worse when it gets warmed up. replace em SOON, and check the piston and so in your brake caliper ! ....something you should do emiedietly
