Sealing the right side of a M66 AWD for a FWD setup.
TheMrFailz
Year and Model: 2002 V70 2.4T
Has thanked: 7 times
Been thanked: 2 times
Post by TheMrFailz »
To keep it short I've got an M66 AWD trans I'm swapping into a FWD '02 V70 and I have no intention of keeping the AWD aspect. I know that the AWD collar sleeve is essentially free floating (although usually frozen) and held in by the angle gear and also keeps the M66 side of the angle gear - trans link sealed fluid wise. Most of the research i've done has basically said "Just stick an angle gear on and don't connect it to a rear driveshaft" but simply put getting my hands on one isn't gonna happen. What I'm looking to know is if I use inhumane amounts of threadlocker on the angle gear sleeve would that be good enough?
In this thread: https://forums.swedespeed.com/showthrea ... Fix-Denied the OP basically just sticks the CV shaft in as a holdover as the angle gear was frozen in place so it wasn't going to fall out. He doesn't mention it leaking at all.
And in this thread: viewtopic.php?f=1&t=79549 the OP does the same thing but uses hose clamps to keep the sleeve from working it's way out. His being technically still freefloating and not frozen it seeps a bit.
I am aware that anyone looking to yank that angle gear in the future is going to basically have to pry it out with a sledgehammer and prybar but I'm doubtful this car will have any more owners, especially ones looking to retrofit AWD on.
Professional jerry-rigger.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
You need a reverse hammer and your share of luck to remove collar sleeve from the differential. Leave it as is, it won't come out on its own.
Angle/bevel gear has two seals that sit on the CV axle. One of these seals is located inside collar sleeve, make sure it is replaced with a new one, since it has to work about twice hard.
TheMrFailz
vtl wrote: 25 Feb 2020, 10:32 You need a reverse hammer and your share of luck to remove collar sleeve from the differential. Leave it as is, it won't come out on its own.
Mmmm there-in lies the problem. Trans as I have it doesn't have a sleeve in there which is why I was worried about a new one falling out since it doesn't have dubious amounts of north east road rust to freeze it. Also I know about the seals but thanks for the headsup anyway.
vtl
Post by vtl »
TheMrFailz wrote: 25 Feb 2020, 16:39 Mmmm there-in lies the problem. Trans as I have it doesn't have a sleeve in there which is why I was worried about a new one falling out since it doesn't have dubious amounts of north east road rust to freeze it. Also I know about the seals but thanks for the headsup anyway.
First press sleeve in =)
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Any update?...did you fit a Angle gear, its the best way in my opinion. How did you go re-tuning the ECM?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
