Fuel filter - best way to relieve pressure?
StickyPocket
- Year and Model: 2004 S60 2.5T AWD
- Has thanked: 42 times
- Been thanked: 6 times
2004 S60, gonna back it up on ramps and replace the fuel filter with a Hengst from FCP. Best way to relieve fuel pressure? Pull the relay while the engine is running?
2004 S60 2.5T AWD
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
There's a schrader valve to the left or near the tank. Unscrew the dust shield, push the pin with something like a tire pressure pen and a rag, then things should be easier.
Also, get a pan below the filter, there will be quite a spill.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
COLD engine. If you do this on a warm engine, the warm fuel will keep 'expanding' and 10 seconds after releasing the pressure at the valve, when you'll pull the sensor out you will get a nice spray - warmly recommend using safety googles. When pushing on the valve, cover it with a piece of paper tower to soak the fuel and not get sprayed . Careful with the sensor screw not to strip the head, the sensor needs twisted while pulling gently and by all means use a little bit of vaseline on the o-ring of the new sensor
On a cold engine, the fuel pressure stays for weeks or months, so always release the pressure, even on a junkyard car.
You also still need to clamp off the upstream fuel hose on the filter
StickyPocket
What sensor screw are you talking about? I wasn't planning on replacing a sensor. Also, am i just opening the shraeder valve? (Where exactly is it?) Am i also pulling the pump relay? I'm reading multiple how-tos and they all seem to have different ways of releasing pressure, and some of them dont at all.oragex wrote: 09 Mar 2020, 04:19 COLD engine. If you do this on a warm engine, the warm fuel will keep 'expanding' and 10 seconds after releasing the pressure at the valve, when you'll pull the sensor out you will get a nice spray - warmly recommend using safety googles. When pushing on the valve, cover it with a piece of paper tower to soak the fuel and not get sprayed . Careful with the sensor screw not to strip the head, the sensor needs twisted while pulling gently and by all means use a little bit of vaseline on the o-ring of the new sensor
Thanks!
2004 S60 2.5T AWD
- oragex
Oh, I presumed you are replacing the FPS sensor.. my mistake. No need for fuel pump relay, just undo the small cap of the valve at the rail, cover with a piece of paper towel - it will protect you and also suck in all the fuel, and depress with something the small pin on the valve. The gas is very hard to clean off hands, and also very smelly - would only do this outside
And this is what happens when working on a warm engine - I had released the valve pressure shortly before this, but since the engine was warm, the gas kept expanding and building pressure - so always work on a cold engine
- chris11211
The valves are, for example, what are on the wheels when you need to put in air into the tires. The part that sticks out and you have to push a pin in to let air in/out. It's the same idea for the gas line. So if you want to release pressure before releasing the fuel filter, then there is a valve between the gas tank and the filter.StickyPocket wrote: 09 Mar 2020, 06:39
Thanks!
- chris11211
chris11211 wrote: 09 Mar 2020, 10:10The valves are, for example, what are on the wheels when you need to put in air into the tires. The part that sticks out and you have to push a pin in to let air in/out. It's the same idea for the gas line. So if you want to release pressure before releasing the fuel filter, then there is a valve between the gas tank and the filter.StickyPocket wrote: 09 Mar 2020, 06:39
Thanks!
That's just how i did it, no need to open the hood, or go anywhere else.
StickyPocket
Replaced it today. Pushed on the Shraeder valve and only a bit of gas dribbled out. Most of the spilling came from the open lines and old filter - but no pressurized spraying.
2004 S60 2.5T AWD
- oragex
There should have been some pressure and hissing sound at the valve, I believe when the small stem is depressed. Will leak only little gas indeed, but must have some pressure to it
- 2676 Views
Last post by cn90
- 16124 Views
Last post by Richard99
- 1226 Views
Last post by volvolugnut
- 6282 Views
- 20 Replies
- 13339 Views
Last post by oragex
