automatic transmission problem
- Has thanked: 987 times
- Been thanked: 1075 times
What is the condition of transmission fluid - Pink, dark red, black? Last known fluid change with filter? Maybe a sticking shift valve?
Could start with fluid change if fluid is dark.
It may help the shifting. However, search for failure after transmission fluid change. Sometimes a fluid change can stir all the junk in the transmission and cause total failure. What is the history on this car and transmission?
Also search this forum for transmission fluid and filter change. The filter is inside the transmission and requires removal of the pan. If you do not think you can do this, a transmission shop can change filter and fluid. Confirm the correct fluid type.
Vehicle has low mileage. Approx 85 to 90K but don't know for sure as the odometer quit a couple of years ago.It is my wife's second car and she rarely drives it. No problems in the past with trans, I just noticed this problem in the last month. I will do the fluid change and see what happens. Thanks again for your input.
I suggest an Italian transmission tune up after a fluid change. Drive it hard while working through all the gears. This car sits too much. Not good for any mechanical thing. If 3 speed with overdrive, then Dextron II fluid should be correct.
I am surprised no one else has commented on this issue.
- 1154 Views
Last post by Krons
- 1582 Views
Last post by jimmy57
- 1521 Views
Last post by SuperHerman
- 732 Views
- 868 Views
Last post by difflock54
