2001 xc70 Replaced my exhaust cam seal, how to get T. B. Back on?
RogeRookie
Year and Model: 2001V70xc
Post by RogeRookie »
Made my marks on both pulleys and timing belt. Replaced exhaust cam oil seal, replaced the pulley exactly. Now this timing belt is a bummer getting back on. To get the pulley off I had to loosen the smooth pulley right beneath the exhaust cam, two bolts. TB slipped off exhaust pulley no prob. How can I get this TB back on ?? Did not need to replace the TB, it had been done recently by previous owner. Thanks, R.
Has thanked: 1609 times
Been thanked: 4064 times
Your 2001 has a variable valve timing on one or both of the cams. Did you have to remove a large tots screw or just three small small hex screw to get to the cam seal?
The setup of the timing belt is bit different in each case
If you know all this and just need help with getting the belt back on, it usually helps to loosen both the tensioner and the smooth idler pulley bolts.
RogeRookie
Thanks for reply. The 3 hex bolts. Ok, I will loosen both "tensioner and smooth idler pulley bolts" and make another attempt. Once I succeed, I will determine if PCV was the cause of seal failure and proceed accordingly. THANKS IN A HUGE WAY. You are an awesome moderator abscate!!!!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If you have a helper, you don't have to remove any pulley. The hardest and most important part here is to first engage the belt on the crank teeth and to keep it there. You can loosen the tensioner bolt, but be sure you know how to set the tensioner back on. But try this first - always careful not to rotate the cams (better lock them). Have all pulleys in place, pass the belt over the crank first and make sure it sits on the crank teeth from underneath, keep tension on it, pass it over water pump, tensioner and idler pulley, then pass the belt over intake cam, then keep the tensioner needle pushed all the way to the right, and slide the belt over the exhaust cam. It should barely slide, but should work. At all moments, keep an upwards tension on the belt so it doesn't 'fall' off the crank pulley teeth and of course make sure the crank doesn't turn (2x check all timing marks at the end).
RogeRookie wrote: 05 May 2020, 10:47 Thanks for reply. The 3 hex bolts. Ok, I will loosen both "tensioner and smooth idler pulley bolts" and make another attempt. Once I succeed, I will determine if PCV was the cause of seal failure and proceed accordingly. THANKS IN A HUGE WAY. You are an awesome moderator abscate!!!!
:oops: :oops: :oops:
Its such a pleasure to contribute here as a mod, because we have such excellent Ladies and Gentlemen who are so civil.
Other than the occasional misspellyng, an improper semi-colonic; a passed participall and a missing Oxford comma all is well in syzygy.
