On my 08 3.2, the lower radiator hose attaches to a 3-way fitting with a metal u-clip/o-ring (same as the thermostat connection to the upper radiator hose).
I unlocked the u-clip but the fitting is still stuck together. I tried prying where where the two pieces come together but that just broke off bits of the plastic flange. These connectors are keyed so it's not possible to twist them.
How can they be separated without destroying the parts?
thanks for your advice!
08 xc90 3.2: lower radiator hose: how do I disconnect?
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
The o-ring sticks and what you are trying to do is the only way to separate. Keep on trying with different tools, multiple tools at once, and different directions of wiggling. If you have to spray a little lubricant in the area, just ensure you clean it off before reassembly.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- ogatrulle
- Year and Model: xc90 2008
- Been thanked: 10 times
Thanks for your suggestions. It was difficult to get leverage so I ended up taking out the 3-way hose (twist-lock connector at the back and hose clamp at the lower front of the engine) and was able to eventually get the radiator hose off. What a pain in the neck!
2006 v70 2.5T; 2008 xc90 3.2
