850 Miscellanous Relays
manovlov
Has thanked: 674 times
Been thanked: 164 times
Post by manovlov »
Hy Buddies !
Some questions :
Here's a pix of my relays "board". Can some one tells me to what correspond the 2 empty spaces ?
If I unplug the anti-theft alarm relay, will it just cut off the alarm, will the car still function normally or will it be immobilized ?
I use this product to help my sunroof to work properly. I have the impression that it's nit a "long life" stuff, I mean it doesn't seem to last longer. Good , Bad, or any better stuff ?
WD 40 Silicon.jpg (29.65 KiB) Viewed 393 times
Thanks.
Manov
Has thanked: 1611 times
Been thanked: 4073 times
I don’t know the relay question.
I use that exact same product in my sunroof, about every 2 months or so.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
I don't know what goes to the empty space, I think it is used or not used depending on if you have a manual or AT car. Not sure about that, though.
What I can tell you though is that you will have to jumper 2 ports of the 210/211 relay, or you won't be able to start it. If you can't find the correct ports shoot me a pm and I will liok it up in my car.
1996 855 R,
2010 V70 D5,
