Fuel injector questions
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 67 times
Been thanked: 9 times
Post by subzerocarfanatic »
I still have not resolved my electrical short issue, i'm taking a break from it for a bit.
I have the fuel rail and injectors pulled out and want to get a rebuild kit for them with seals,filter etc. , does anyone know if there is an OEM kit or have a part# please!
All the injectors Ohm out at 12.5 is that about normal for these,it has the BOSCH
9186060 0280155830 injectors.
subzerocarfanatic
I have another question....can the green injectors used standard on the 2000 V70 R rated at 468 cc/min? I have the blue ones in my C70 2.3 Turbo which are rated at 395 cc/min I believe. I know the white and the blue injectors have the same flow but different specs because different Volvo models have different fuel pressure so theoretically the whites could be used in a different model with higher fuel pressure,I was just curious if anyone has ever tried using the green ones in the C70.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
The green injectors are 440cc/Min @ 43.5psi. There is no sense in using the green injectors unless you push enough oxygen into the cylinders to burn fuel at that rate. R and T5 owners with the K24 turbo can do it.
subzerocarfanatic
So if the turbo was upgraded then.Not doing it now just things to consider in future.
RickHaleParker
subzerocarfanatic wrote: 18 Jul 2020, 17:08 So if the turbo was upgraded then.Not doing it now just things to consider in future.
Turbo upgrade, tune and injector upgrade. If you just want it for wide open throttle applications, a dry nitrous system and injector upgrade will do.
Has thanked: 293 times
Been thanked: 765 times
Post by erikv11 »
Never change injector flow rate unless you also install a tune that matches the new flow rate. Never.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
RickHaleParker
erikv11 wrote: 18 Jul 2020, 18:20 Never change injector flow rate unless you also install a tune that matches the new flow rate. Never.
Fuel trim "tunes" the air/fuel mixture.
Post by erikv11 »
Ah yes, rely on fuel trims to take care of the mismatch. Great way to run occasionally rich, occasionally lean.
'06 S60 R, 197k
