The bolt that mates the VVT to the cam shaft is torqued to about 85-90 ft*lb...
Do you rely on the torque only?
Does anyone here add a drop of Loctite to make sure it does not come loose?
2.5T VVT Hub center bolt question...
Volvo say no, so I don’t. It’s too oily for loctite to setup right anyway, I think.
90 ft lbs is really tight. It’s not going anywhere
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I don’t, and I clean my bolts with brake parts cleaner.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
The bolt is clean, no thread glue on it. Make sure the three outer hub to sprocket bolts are tight, mine were slightly loose. Ive read of someone that had these bolts fall of, made lots of noise as the hub turned.
https://forums.swedespeed.com/showthrea ... -to-repair
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
It would be like putting loctite on lugnuts.cn90 wrote: 15 Aug 2020, 15:25 The bolt that mates the VVT to the cam shaft is torqued to about 85-90 ft*lb...
- Been thanked: 504 times
The link below says we need 3/4" drive T55 bit...
http://volvospeed.com/vs_forum/topic/15 ... ng-timing/
My T55 bit is 3/8" type.
Thoughts?
Thoughts?
A 3/8 t55 will work fine. I’ve never heard of this breaking, but make sure your T55 bit is sharp and new. If the bolt looks gnawed on, pm me for a spare.
- 9260 Views
Last post by volvolugnut
- 2602 Views
- 12 Replies
- 3744 Views
Last post by JimBee
- 769 Views
Last post by RickHaleParker
- 912 Views
Last post by lcc014
