The oil cooler on white engines
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
These questions regard the oil cooler on the backside of the 5 cylinder engines. It has 2 hose connections.
The cooler has a flat side which mounts against the engine with 2 seals. I assume the seals press against piping within the engine.
What flows where?
I'm guessing the cooler has oil pumped through it via the ports in the contact surface and that coolant is what is piped through the hoses.
That the heat energy is transferred from the oil to the coolant is why the cooler doesn't resemble any other "open finned" radiator.
My other guess is that only a portion of the engine's oil, ~20%, is sent through the cooler.
How close am I?
Has thanked: 1610 times
Been thanked: 4068 times
Full flow
Oil through flat ports
Coolant through pipes
Pictures here!
viewtopic.php?f=1&t=83718&start=10
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Yes two oil seals and they cannot be reused (i tried), i removed that cooler to fit my anglegear not realizing the oil ports. From memory only a small amount of oil comes out NOT the whole engine oil.
If you remove the plastic cover there are fins under, not sure why its covered with plastic...
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
