Non Nivomat Springs on Nivomat
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
Has anybody ran non nivomat rear springs on a car still equipped with Nivomat shocks?
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- befarrer
Oh, I'm talking about an AWD V70 here too. I have nivomat suspension right now, I will be needing new spring perches soon, and likely installing the coilover perches as thats all that is available. I plan on removing the nivomat shocks, but if I have the springs out, may as well put in the stiffer ones then when I get shocks, I just have to change them.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Apologies, I seemingly forgot how to read. Everything I said above needs to be reversed. Non-nivomat springs will have too high a spring rate, and be 50mm too short. The spring cup part is still correct, at least.
You don't need to remove the springs to change the Nivomats or to install a conventional damper.
I'm rather confused about your plans, to be honest. To clarify, you intend to swap your Nivomat setup to a normal spring and damper set-up. You're looking to get the springs now (presumably the damper later?) and as such are wondering if you can fit the springs in advance?
If that's all correct, if, then it is unadvisable as the non-nivomat springs are not compatible with the Nivomats. If you have a problem with your current springs (is that the case?), i.e. they've broken or cracked, then your best bet is to replace with nivomat springs from a breaker until you can afford to replace the whole rear set-up. If your current coils are not broken I do not understand why you would have them out?
- alpha318
- Year and Model: 94 Volvo 850 Turbo #
- Has thanked: 6 times
- Been thanked: 2 times
I do have a request!!
When all of this is said and done, could you please share your part numbers and sites? That'll be awesome.
Those who say, "Money can't buy happiness", obviously never bought a turbo charged car, or paid a pet adoption fee!
- 965 Views
Last post by erikv11
- 672 Views
Last post by bmdubya1198
- 3120 Views
Last post by foggydogg
- 3822 Views
Last post by jcdillin
- 2209 Views
