Hello:
I recently replaced the alternator with a remanufactured Bosh, and installed a new Interstate battery. Unfortunately, I am only 13.42 volts while the engine is running without any accessories on.
Please advise
Low voltage after battery and alternator replacement
VolvoAffair
- Year and Model: 1998 S70
- Been thanked: 4 times
- RickHaleParker
- Been thanked: 978 times
So far I don't see anything that warrants concern.
Measure the battery voltage after a 30 minute rest. Post the measurement.
Alternator range is 13.5V - 14.5V. The Alternator voltage will drop to 13.5V when the battery is fully charged.
Keep in mind the voltmeter might be a little off or there might be a small voltage drop across the length of the voltmeter leads. Which can account for the missing .08V.
You can try discharging the battery to about 13.0V. Then start the engine and measure the alternator voltage as it charges the battery up.
Active
Past
Past
- 5564 Views
Last post by hans747
- 467 Views
Last post by BEJinFbk
- 528 Views
Last post by Laptoploon
- 25 Replies
- 3154 Views
Last post by RickHaleParker
- 12 Replies
- 3769 Views
Last post by XC60aches
