coil spring spacers
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
Has anyone had success using rear coil spring spacers? I'm just looking to lift the back end about 1/2" to 1". A couple years ago I bought the blue spacers that IPD sells. They didn't seem tall enough to make any difference. Other suggestions? Recommended sizes/dimensions/manufacturers?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Only recently joined a truck board...lifting is completely new to me. Shocks hitting limits internally is always cited.
Raising the nose of V70's and leveling has come up.
Don't have exposure or knowledge.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I too want to lift the rear a little - my front got lifted from new shocks. I will try see if the rear springs for 98-06 S80 are thicker, perhaps they will jack the rear of the S60 a little - not tested yet
- oragex
The original question being about an S60, I went at the junkyard and measured the thinness of the rear springs. The S60 and S80 appear to have the same coil spring thinness, while the V70 has slightly thicker rear coil springs - all these being FWD cars. So a rear FWD V70 spring should lift a little the rear of an S60.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
Spring rate=(G(D^4))/(8N(M^3))
G=11,250,000
D=Wire diameter in inches
N=Number of active coils
M=Mean coil diameter in inches (Outer diameter of coil spring minus wire diameter)
Not sure if that helps anything, but that'll give you the spring rate in pounds/inch.
G=11,250,000
- 477 Views
Last post by T64me
- 751 Views
Last post by Kazthebassman
- 3185 Views
Last post by Arwing
- 2089 Views
Last post by Bamseclub
- 425 Views
Last post by 940J95
