Hi. I have had my XC70 Auto/Geartronic for the past 2 years and have had no problems but suddenly last wknd 'something' stopped working! The car lost all drive and left us stranded in the middle of nowhere! Having gotten it back to a local garage they tell me that the drive shaft is broken and needs replaced! Sounds expensive! What I couldn't understand is why, with the XC70 being AWD did I lose ALL drive at once? If this is a stupid question please forgive me.
If anyone is able to give me advice, I would be very grateful.
Thanks in advance.
Steven
2005 XC70 sudden loss of drive
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
the right hand front and rears are driven from one side RH of the gearbox, the front left driven by the LH side. i think the way the gearbox works, it spins the easiest wheel..but the 2005 has an electronic AWD this should stop it and put power to the other wheel that isnt moving, thats what i thought.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
You may always try to find a used part in good condition. Were there any noises before ? A drive shaft doesn't break all of a sudden without making noise prior to that. Was the engine still running when this happened, or it also died ? Could you start the car ? https://www.volvoforums.org.uk/forumdisplay.php?f=19
- RickHaleParker
- Been thanked: 980 times
1. Part time AWD. The AWD does not engage unless the TCM detects wheel slippage on the front drive. The sensors are in the wheels. The wheel has to be spinning for wheel slippage to be detected. This is why your AWD is not engaging.jura0107 wrote: 22 Oct 2020, 10:20 What I couldn't understand is why, with the XC70 being AWD did I lose ALL drive at once?
2. Differential slip is what you get when stuck in the mud. The wheel that is in the mud spins goes nowhere and the other one does nothing. The broken axle causes Differential slip just like getting stuck in the mud.
Was the CV joint making a clicking noise before this sudden lost of drive? If so, this is not sudden. You where warned long before this happened. Most of the time it the CV joint on the Axle that is broken not the Axle.
Active
Past
Past
jura0107
- Year and Model: 2005 XC70
- Has thanked: 3 times
Thanks RickHaleParker for your advice. I use the word 'sudden' because to me and my family it was! I am not a mechanic and have to rely on others such as yourself, for guidance in these matters. There may well have been any number of 'noises' that I would not have interpreted as being an indicator of a major problem like this - the car is, after all, about 15 years old
Thanks for the explanation tho', it was helpful. Best, Steven.
jura0107
Thanks for your reply. I didn't notice any unusual noises before it happened. The car was running and it still starts fine - it just wont engage any gears.oragex wrote: 23 Oct 2020, 12:17 You may always try to find a used part in good condition. Were there any noises before ? A drive shaft doesn't break all of a sudden without making noise prior to that. Was the engine still running when this happened, or it also died ? Could you start the car ? https://www.volvoforums.org.uk/forumdisplay.php?f=19
- darrylrobert
pics of the "broken axle" would be interesting. could be just a universal joint. Only time my volvo has broken down was because of getting work done by "mechanics". I also check my vehicle after having work done and have found important bolts not done up etc..Most mechanics will show you/explain what is broken or has been fixed.
- RickHaleParker
Was it these guys?
Active
Past
Past
- Been thanked: 4071 times
Hey, I didn’t give permission for my shop to be on here!!
- 1136 Views
Last post by father ted
- 15 Replies
- 3159 Views
Last post by wizechatmgr
- 751 Views
Last post by maartenr
- 3413 Views
- 12 Replies
- 8532 Views
Last post by ggleavitt
